Determine your Actual Vehicle Speed
Crawl Ratio Calculator
Need to compute gear ratios for an appropriate vehicle speed?
Use this form to calculate your vehicle speed (approx.)
Unfortunately designed for Microsoft Internet Explorer
Note:
    Tire size assumes that a 35" tire is exactly 35" in diameter.
    Tread wear / over inflation will effect actual size under extreme conditions. Also, a balloon factor will effect size at high velocities, so use this as a close approximation.
Established Final Drive Ratio
Engine Speed (RPM)
Tire Size (in)
Final Drive Ratio
Your Vehicle Speed is:  MPH
 Previous Speed #1:  MPH
Previous Speed #2:  MPH
More Specific Final Drive Ratio
Engine Speed (RPM)
Tire Size (in)
Transmission Gear Ratio:
Crawl Box #1:
Crawl Box #2:
Transfercase:
Ring & Pinion Ratio:
How do I determine what ratios I have?
Table of most common Toyota Crawl Ratios
Toyota 4WD First Gear Transmission Ratios
Close this window
