Determine your Crawl Ratio
Vehicle Speed Calculator
Use this form to calculate your final crawl ratio
Unfortunately designed for Microsoft Internet Explorer
*The form currently only supports up to a tripple transfer case setup.
Transimssion Ratio
Crawl Box #1
Crawl Box #2
Transfercase
Ring and Pinion
Your Final Crawl Ratio is:
 Previous Ratio #1:
Previous Ratio #2:
Determine your Actual Vehicle Speed vs. Gear Ratios and Tire Sizes
How do I determine what ratios I have?
Table of most common Toyota Crawl Ratios
Toyota 4WD First Gear Transmission Ratios
Close this window
