Click here to return Home
    Return
Transmission Specification
  W56-B Transmission
The W56-B was used on 1986-1988 EFI Toyota Pickups and 1986-1989 EFI 4Runners. This model can be identified by having both a cast steel center section and a single shifter. This transmission is 25 3/8" long and weighs 85 lbs as pictured. The center of the trans shifter is 21" back from the front edge of the bell housing.
  • Years used: 1986 - 1989
  • Uses Type 3 top shifting transfer case.
W56-B Transmission
W56-B Right Side View
Right Side View
W56-B Front View
Front View
W56-B Left Side View
Rear View
Model 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear Reverse
W56 3.95 2.14 1.38 1 .85 4.09
Transmission Identifing Input Bearing Number
W56-A, B & C 6307-N, HR6307-N
W56 Internal Rebuild Kits
Transmission rebuild kits feature NSK & Nachi Japanese made bearings and include seals & gaskets. See HD bearings
External Replacement Boots
OEM Factory Toyota clutch fork and shifter boots.
Add To Shopping Cart Clutch Fork Pivot Boot, $11.38 each
Add To Shopping Cart Transmission Shifter Boot (W56 A/B), $10 each
Shift Fork Boot
Click here to Return to your Previous Page
