| Transmission Parts & Accessories |
Heavy Duty Shifter Seat It's
common for the factory shifter seat to wear, crumble and disintegrate over time.
This often results in a sloppy or loose transmission shifter. The factory seat is
soft so it can be squeezed into position. We took a different approach, and
machined groves into the sides of our heavy duty seats. Instead of squeezing the
seat into place, the groves on each side allow ours to rotate into position. This
allows us to make our seat from stronger, longer lasting hardened urethane. Our new
heavy duty seats will far out last the stock units and will reduce shifter slop.
Please state year and model when ordering. Two different sizes, one sizes fits W56A
and W56B models, the other fits all other 4wd applications as well as all Toyota
Celicas and Supras.
See Install Information
MC-10076, Heavy Duty Shifter Seat, W56 A or B $10 |
MC-10077, Heavy Duty Shifter Seat, All Other Toyota Transmission Applications, $10 |
MC-10079, Heavy Duty Shifter Seat, Forward Shift Transfercase Handle, $10 |
MC-10078, Shifter Socket $6 |
Heavy Duty Bearing Cover Plate
Included free on all R-transmission
rebuilds! Fits all R-series transmissions [R150F (V6),
R151F (Turbo 4Cyl), R154 (Supra), etc]. CNC machined from top quality tool steel
and will long out live the factory original. As the factory unit wears out it
fails to properly position the main shaft. This heavy duty unit does a much
better Job of holding the shaft in the proper position. Includes set of 4 bolts.
MC-10075, Heavy Duty Bearing Cover $45 |
External Replacement Boots
OEM Factory Toyota clutch fork and shifter boots.
Clutch Fork Pivot Boot, $11.38 each |
Transmission Shifter Boot, W56A/B, $10 each |
Transmission Shifter Boot, All Others, $6.74 each |
