V6 Transmission To Gear-driven Transfer Case
1988-1995 V6 5-Speed Pickup/4Runner
1993-2005 V6 5-Speed/Automatic T-100
1) After removing right-hand front
output chain drive transfer case, grind the lower right corner of your
V6 transmission as required using the supplied gasket as a template.
Make sure that both dowel pins remain in the transmission to properly
align the adapter plate.
2) Install the plate and gasket to the
front of the replacement gear-driven transfer case, using the four "A"
bolts, one "B" bolt, and one "D" bolt w/lock washer. Torque to 26-30 ft.
lbs.
3) Lube the sealing lip and replace the
transmission output seal.
4) Install the 23-spline coupler until
it bottoms on the transmission output shaft (this is a tight fit). When
properly installed, the coupler will protrude 2 1/2" from the end of the
mainshaft.
5) Install the transfer case assembly
and torque all bolts shown in photo below to 25-20 ft lbs. Remember to
seal the lower two "B" bolts with silicone.
