Click here to return Home
  Dual Transfer Case
  Crawler Gears
  Tacoma Taco Box
  Land Cruiser Toy Box
  Parts & Accessories
Tacoma Dual Transfer Case
    In 2002, Marlin Czajkowski developed the world's very first Tacoma/4Runner Dualcase Crawler. Based on the bullet-proof double roller MC08 Billet Aluminum Dualcase Adapter, Marlin expanded his product line to include the Tacoma-series drivetrain, and ushered in a whole new series of adapters. Marlin Crawler is the first company in the world to offer a Dual Case setup in a Tacoma/4Runner by placing a Hilux Gear Drive Redution Housing in between a Tacoma/4Runner Transmission and Chain Drive Transfercase. This extra Low Range unit comes standard with a 2.28:1 Low Range, and can also be fitted with our 4.70:1-TS™ Gear Set.
    In order to install a Hilux Low Range Reduction Housing between a Tacoma/4Runner Transmission and Transfercase, two adapters are required to get the job done. For the front adapter we use a 1/2" thick Billet Aluminum Plate to mate a Hilux Reduction Housing behind the Tacoma/4Runner transmission. And for the rear adapter we use another Billet Aluminum Plate to bolt a Tacoma/4Runner Chain Drive Transfercase behind the Hilux Low Range Housing. And what we end up with is the Marlin Crawler TacoBox™, a fully assembled Dualcase Unit.
    The heart of the TacoBox™ is the rear adapter, the Marlin Crawler MC09. This 6th generation Dualcase Adapter features everything you'd expect from the quality and reliability of Marlin Crawler. First we machine a block of solid Billet T6061 Aluminum on a CNC mill. Then we use our 32-Ball Double Roller Bearing, the same double roller bearing that has proven itself since 1999. Next we create a Heavy Duty Oversized Coupler and Heat Treat it for the ultimate in strength and reliability.
Click here for a larger picture
New Rotated MC09-R10 with
New Rotated 34-4GT-R10
Click for 1300x1300 Image
It is nice to know that the Tacoma TacoBox™ MC09 Adapter features the same exclusive advanced reliability design as the Hilux Adapters, something Marlin created over 7 years ago! So if you have ever wondered why the Marlin Crawler has stood out from the rest then I invite you to review the following article:
Understanding the Success of the Marlin Crawler
The Tacoma TacoBox™ is designed from the strongest and most reliable Toyota Dual Transfer Case System in the World.
    The end result is the MC09 Adapter. This adapter allows a gear drive reduction housing to mate to the front of a Tacoma/4Runner chain drive transfercase.
New Rotated Front Adapter Plates
    The front Adapter Plate is much more simple than the Rear, but it plays an equally important role. Shown to the left is our New 34-4GT-R10 Adapter. It is just like our 34-4GT adapter (invented in 2002), but it has a Rotation option of 10-degrees to help get the front driveline up and out of the rocks. When combined with the MC09-R10 adapter, a total rotation of 20-degrees is achieved.
    Like the Rear Adapter, the Front Adapter is made from a solid piece of Billet T6061 Aluminum. Again Marlin realized that the coupler is perhaps the most important component of these kits, so he built the adapter around a special heat treated oversized coupler. This Front Adapter plate (like the 30-4GT) allows a Hilux Gear Drive Reduction Housing to be bolted directly behind a Tacoma/4Runner 5-speed or Automatic Transmission.
    The Front Adapter part numbers are designated to eaisly identify each Application:
  • 27-4GT -> 2.7L Auto or Manual Trans to 4-cyl Gear Drive T/case.
  • 34-4GT -> 3.4L Auto or Manual Trans to 4-cyl Gear Drive T/case.
Installed in a 1999 4Runner. Click above for Pictures!
    The TacoBox™ is available for all 4WD 4-cylinder (2.7l) or 6-cylinder (3.4l), manual or automatic transmssion, Right-Hand or Left-Hand front output, IFS or SAS (Solid Axle Swap), 1995.5-2005 Tacoma or 4Runner, 2.28:1, 4.00:1, 4.70:1, 4.97:1 available Gear Ratios. The TacoBox™ is a highly versitle Dualcase Marlin Crawler that will work with nearly any type of drivetrain under your Tacoma/4Runner today.
Final Drive Crawl Ratio Chart
Left-Hand Setup (Chain Drive)Right-Hand Setup (Gear Drive)
TacoBox™
Ratio
Ring & Pinion
5 Speed Manual
4cyl
(W59)
6cyl
(R150F)
Auto
4 & 6 cyl
(A340x)
5 Speed Manual
4cyl
(W59)
6cyl
(R150F)
Auto
4 & 6 cyl
(A340x)
1.00:14.11:142:140:130:137:136:126:1
1.00:14.88:150:148:135:144:143:131:1
1.00:15.29:154:152:138:148:146:134:1
2.28:14.11:195:192:167:184:182:160:1
2.28:14.88:1113:1110:180:1100:197:171:1
2.28:15.29:1122:1119:187:1108:1105:177:1
4.00:14.11:1167:1162:1118:1148:1144:1105:1
4.00:14.88:1198:1192:1140:1175:1171:1125:1
4.00:15.29:1215:1208:1152:1190:1185:1135:1
4.70:14.11:1196:1190:1139:1174:1169:1123:1
4.70:14.88:1233:1226:1165:1207:1200:1146:1
4.70:15.29:1252:1245:1179:1224:1217:1159:1
4.97:14.11:1207:1201:1147:1184:1178:1130:1
4.97:14.88:1246:1239:1175:1218:1212:1155:1
4.97:15.29:1267:1259:1189:1237:1230:1168:1
4.00:1 and 4.97:1 (5:1) are generally not recommended due to their inherent weak design.
For Automatics, we recommend anywhere from 70:1 to 100:1 as an Ideal Crawl Ratio.
A TacoSupreme™ is a TacoBox™ equipped with a set of 4.70:1 gears.
TacoBox™ Assembled Unit
Left-Hand Front Output
    This is a Completely Assembled RTI (Ready To Install) Unit for a Left-Hand front output setup. Unit is assembled with our MC09(-R10) Dualcase Adapter and our xx-4GT-R10 front adapter plate. Clockable options include 0-Degree, 10-Degrees or 20-Degrees. Please specify your desired rotation during check-out.
    Includes: TacoBox™ Unit, Oversized Coupler, Seal Adapter, Sealant, Attaching Hardware, and a Shift Handle with our Marlin Crawler Turtle Knob. 4.00:1 and 4.97:1 ratios available on request.
TacoBox™ Complete Unit
Note: All 4-cylinder applications temporarily out of stock!
  Gear Ratio Applications Part Number Base Price
Add To Shopping Cart TacoBox™
2.28:1
4cyl, 6cyl
5spd, Auto
MC-14570 $1,449
Add To Shopping Cart TacoSupreme™
4.70:1
4cyl, 6cyl
5spd, Auto
MC-14571 $1,899
Do-It Your-Self Kits
Crawl Box to Stock Transfer Case Adapter
Add This Item Shopping Cart MC-14120, MC09 Dual adapter Kit $649
Transmission to Gear Drive T/case Adapters
Add This Item Shopping Cart MC-14121, Model# 27-4GT 2.7L 4Cyl / 5-Speed, $349
Add This Item Shopping Cart MC-14122, Model# 34-4GT 3.4L V6 / 5-Speed, $349
Add This Item Shopping Cart MC-14123, Model# 27-AT 2.7L 4Cyl / Automatic, $399
Add This Item Shopping Cart MC-14124, Model# 34-AT 3.4L V6 / Automatic, $399
Add This Item Shopping Cart MC-14050, 23 Spline 4.70 Total-Spline™ Input Gear, $159
Add This Item Shopping Cart MC-14051, 23 Spline 2.28 Total-Spline™ Input Gear, $159
Installation service available on all transfer case kits & components. Typical dualcase installation cost is $900 including heavy duty drive shaft retubing. Solid front axle converted Tacoma's will also need an additional custom cross member to allow for drive shaft movement.
Please see Steve's Installation Pictures here: MC09 Install Pictures.
