Click here to return Home
  Dual Transfer Case
1 Adapters
  Crawl Box
  Dual Ultimate
  V6 Duals
  V6 Kit
  Crawler Gears
  Tacoma Taco Box
  Land Cruiser Toy Box
  Parts & Accessories
Dual Transfercase Setup
Marlin Crawler was the first to bring dual transfer cases to the USA and the first in the world to bring low range gear kits to the Toyota market. As the leader in Toyota transfer cases we build the best units period. We can give you the low range, slow crawling gears your looking for.
Installing a dual transfer case into a 4-cyl equipped truck requires moving your existing t/case back approximately 6.5 inches. The additional crawl box is installed between the transmission and t/case. All 4-cyl gear driven t/cases are 21-spline except for the 1986-87 turbo, which is 23-spline. 2.28:1, 4.00:1, or 4.70:1 gears can be used in any combination in the two t/cases. The most common choice is one set of 2.28:1 gears and one set of 4.70:1 gears, known as a Dual Ultimate Crawler. When building a transfer case for 4-cyl applications, the stock 21-spline input gear can be used. When building turbo, V6 & V8 applications, we highly recommend using a 23-spline input in the rear t/case. Otherwise, failure of a factory 21-spline input gear is certain. Floorboard and drive shaft modifications are required. The factory crossmember remains in its original position.
Understanding the Success of the Marlin Crawler
Have you ever wondered what makes the Marlin Crawler stand out from the rest? Or why the Marlin Crawler is the most reliable Dual Case Adapter on the market? If you would like to know why Marlin Crawler has established such an Amazing track record, then please read this article, which clearly explains why the Marlin Crawler is the strongest and most reliable Toyota Dual Transfer Case System in the World.
MC07 Dual Transfer Case Adapters
Kits Includes: Double bearing adapter housing, new oversized billet main shaft, double roller bearing pressed and installed, Cage roller bearing pressed, installed, and greased, Marlin Crawler Turtle Knob key way for shift fork, Toyota transmission output seal, Toyota gasket and seal kit, attaching hardware. Install Instructions
Add This Item Shopping Cart MC-14100, MC07, 21 Spline Kit, $369
Add This Item Shopping Cart MC-14101, MC07, 23 Spline Kit, $369
Add This Item Shopping Cart MC-14106, MC07-R10, 21 Spline Kit, $369
Add This Item Shopping Cart MC-14107, MC07-R10, 23 Spline Kit, $369
MC08 Dual Transfer Case Adapters
This special Billet aluminum adapter is also available in standard or rotated fashion. The standard version is just like the MC07 above, except it is made with Billet Aluminum which is much stronger than its Cast counterpart. The rotated variant rotated the rear transfer case left by10 degrees. This lifts up the 4WD front section so that it is level with the rest of the transfer case. Increases clearance under case by 1-3/16", and also raises the front driveline which furthure improves ground clearance and helps prevent driveline damqage. Requires slight bending of rear shifter.
Add This Item Shopping Cart MC-14102, MC08, 21 Spline Kit, $499
Add This Item Shopping Cart MC-14103, MC08, 23 Spline Kit, $499
Add This Item Shopping Cart MC-14104, MC08-R10, 21 Spline Kit, $499
Add This Item Shopping Cart MC-14105, MC08-R10, 23 Spline Kit, $499
MC07/MC08 Dual Adapter
MC07-R10 Adapter Kit
Assembled MC08-R10 Unit
Assembled R10 Adapter
Learn more about the
amazing Marlin Crawler
Select Units are assembled, in stock, and ready to ship!
Please call for more details!
Ready-To-Run Crawl Boxes
Dual Marlin Crawler transfercase Crawl Box Unit featuring 21 or 23-spline, 2.28:1 or 4.70:1 gear ratios. Complete, Ready-To-Run Reduction Unit featuring our World-Famous Double Roller Cast or Billet Aluminum Adapter Plates. No Crawl Box Assembly or Disassembly Required. All necessary hardware included. Includes factory shifter assembly with a Marlin Crawler Turtle Shift Knob. Unit installs between transmission and transfer case. Floorboard and driveshaft modifications are required. Fits 1979-1995 gear driven transfer cases, 4 & 5 Speed applications. No core charge.
P/N Model Ratio Spline Price
Add This Item Shopping Cart MC-14400 MC07-U 2.28:1 21 $719
Add This Item Shopping Cart MC-14401 MC07-U 2.28:1 23 $869
Add This Item Shopping Cart MC-14402 MC07-U 4.70:1 23 $1,168
Add This Item Shopping Cart MC-14400R MC07-R10-U 2.28:1 21 $719
Add This Item Shopping Cart MC-14401R MC07-R10-U 2.28:1 23 $869
Add This Item Shopping Cart MC-14402R MC07-R10-U 4.70:1 23 $1,168
Add This Item Shopping Cart MC-14403 MC08-U 2.28:1 21 $849
Add This Item Shopping Cart MC-14404 MC08-U 2.28:1 23 $999
Add This Item Shopping Cart MC-14405 MC08-U 4.70:1 23 $1,298
Add This Item Shopping Cart MC-14406 MC08-R10-U 2.28:1 21 $849
Add This Item Shopping Cart MC-14407 MC08-R10-U 2.28:1 23 $999
Add This Item Shopping Cart MC-14408 MC08-R10-U 4.70:1 23 $1,298
2.28 Crawl Box
21-Spline 2.28:1
MC07-U Crawl Box
2.28 Crawl Box
This is the ultimate setup for your rock crawler. Features our 4.70 gears in the rear case and MC07 dual adapter plate. 20 forward and 4 reverse gear combinations.  Fits 1979-1995 gear driven transfer case applications. 4 & 5 Speed application only. 4.00 or 4.97 gears available upon request. One t/case shifter included, reuse your original shifter in second position.
Additional $250 core charge will be refunded upon return of single stock gear drive transfer case.
Add This Item Shopping Cart MC-14450, Transfer Case Assembly, Dual 2.28 & 4.70 4Cyl 21 Spline, $1,445
Add This Item Shopping Cart MC-14470, Transfer Case Assembly, Dual 2.28 & 4.70 4Cyl 23 Spline, $1,619
Installation service available on all transfer case kits & components.
3.0L V6 Dual Case Setups, 1988-1995
Installing a dual transfer case into your 3.0L V6 truck can be done in two ways: 1) By using two gear driven transfercases, you can replace your stock Chain Drive transfercase with a Gear Driven Dual Case Transfercase. 2) By using one gear drive transfercase low range Crawl Box, a 100% bolt-in Dual Case Unit can be installed between your factory transmission and factory chain drive transfercase. We have been using the Gear Drive Transfercases and its components for over ten years and have found them to be most reliable. We believe that a 1979-95 Gear Drive Transfercase is stronger than a 1988-95 Chain Drive Transfercase. The biggest problem with the Chain Drive Transfercase seems to be with its input gear, which we have seen fail.
The Chain Drive Transfercase uses a 2.56:1 planetary gear reduction, which, due to reliability concerns, we do not offer lower gearing options for. With this said, a Chain Drive Dual Case setup is limited to the addition of a 2.28:1 (or 4.00, 4.70, 4.97) MC10-R10 Crawl Box. A combined Reduction of 5.84:1 is standard and a 12:1 is the optional Ultimate setup using the 4.70:1 ratio (please note that the 4.00 and 4.97:1 gear ratios are generally not recommended).
The Gear Drive Transfercase uses a standard 2.28:1 gear reduction, and may be swapped for a 4.70:1 (or 4.00/4.97 if desired). When combined with our Gear Drive Dual Case Unit of 2.28:1, a standard combined reduction of 5.19:1 is achieved while a 22.09:1 is the optional Double Ultimate setup using two sets of 4.70:1 gears, something that is NOT possible in a Chain Drive Dual Case Setup.
Floorboard and drive shaft modifications are required, while the factory crossmember is retained and remains in its original position.
Ready-To-Run V6 Gear Drive Dual Crawler
1988 - 1995 Pickup/4Runner V6 Dual case assemblies. Completely assembled dual case V6 unit ready to bolt in. Replaces factory chain drive transfer case. Comes with assembled V6 adapter plate and all mounting hardware & tcase mount. Includes Marlin Crawler Turtle Shift Knob and shifter. No core charge. 4.00 & 4.97 gears also available.
On 1992-95 Applications, an Electronic Vehicle Speed Sensor is required (see below).
Add This Item Shopping Cart MC-14550, Transfer Case Assembly, Dual 2.28 & 2.28 V6, $1,619
Add This Item Shopping Cart MC-14560, Transfer Case Assembly, Dual 2.28 & 4.70 V6, $2,065
Ready-To-Run V6 Chain Drive Dual Crawler
1988 - 1995 Pickup/4Runner V6 Dual Case Unit. This MC10-R10 Marlin Crawler is a rotated adapter plate with our famous Double Row Bearing that allows the installation of a 1979-95 Gear Drive reduction unit between your 3.0 V6 Transmission and 1988-95 Chain Drive T/case. This Unit is completely assembled (pictured to the right) and ready to be fitted between your stock 3.0 V6 transmission and chain drive transfercase. Standard Low Range is 2.28:1, and can be upgraded to a 4.70:1 Low Range Gear Set for the Ultimate Crawl Ratio. Includes Marlin Crawler Turtle Shift Knob and shifter, and a replacement transmission mount. No core charge. 4.00 & 4.97 gears also available but are generally not recommended.
The MC10-R10-K Kit is NOT Ready-To-Run. It includes the MC10-R10 Adapter kit assembled with Bearings and Dowel Pins, Coupler, thrust washer, required hardware, and Turtle Knob. A Front Adapter P/N# 30-4GT (see below) is required to adapt to the gear drive Crawl Box, and a Donor 1979-95 Gear Drive Transfercase is required to assemble the Crawl Box.
Add This Item Shopping Cart MC-14551, MC10-R10-U 3.0 V6 Chain Drive Dual Case Crawl Box, 2.28:1, $1,299
Add This Item Shopping Cart MC-14552, MC10-R10-U 3.0 V6 Chain Drive Dual Case Crawl Box, 4.70:1, $1,749
Add This Item Shopping Cart MC-14553, MC10-R10-K 3.0 V6 Chain Drive Dual Case KIT, 2.28:1, $649
Add This Item Shopping Cart MC-14553, MC10-R10-K 3.0 V6 Chain Drive Dual Case KIT, 4.70:1, $1,099
V6 Gear Drive Dual Crawler Kits
V6 Dual t/case kit. Requires 2 4-cyl gear driven top shifting t/case assemblies. Rear t/caser input must be 23-spline. Dual kit includes V6 plate, MC07 dual adapter, and (2) input gears. Dual Ultimate kit includes V6 plate, MC07, 1 input gear, and 23 spline 4.70 gears for the rear case. 4.00 & 4.97 gears also available.
V6 Adapter Plate Instructions
Add This Item Shopping Cart MC-14202, Transfer Case Kit, Dual 2.28 & 2.28 V6, $1019
Add This Item Shopping Cart MC-14203, Transfer Case Ultimate Kit, Dual 2.28 & 4.70 V6, $1,319
V6 Adapter Plate
Allows 4Cyl gear driven transfer case to bolt onto 1988-1995 3.0L 5speed V6 transmission replacing chain drive case. New Updated design now includes a special Seal Adapter (not pictured).
Add This Item Shopping Cart MC-14210, 30-4GT V6 Adapter Plate, $349
Triple Drilled Flanges
Our flanges feature all the 84 and up popular patters. Makes fitting drive shafts with other patterns much easier. Bolt on installation.
Add To Shopping Cart MC-14660, Transfer Case Flange, $35
Add To Shopping Cart MC-14661, Differential Flange, $35
Total Spline™ 2.28:1 Turbo Input
Marlin Crawler's Exclusive Total Spline™ 23-spline 2.28:1 transfercase input gear. Originally for Factory 1986-1987 Turbo Transfercase input gear. Accepts 5spd transmission outputs of R150F (3.0L V6) and R151F (2.4L Turbo I4). Fits any gear driven t/case 1979-1995. Factory 2.28:1 Gear Ratio.
Don't settle for Non-Total-Spline™ technology!
Do it right the first time and never worry about strip-outs or input failure again!
Add This Item Shopping Cart MC-14211, 23 Spline Input Gear, $159
Marlin Crawler VSS
We are now producing our very own Vechicle Speed Sensor (VSS). This 3-wire, 4-pluse magnetic pulse amplifier will convert ANY Toyota vehicle with a standard 22x1.50 mechanical speedometer drive to an electronic speedometer system. Features a standard Toyota VSS Plug for your convience. The Applications are unlimited, converting both 4WD and 2WD 22x1.50 mechanical speedometer setups to electronic 3-wire, 4-pulse speedometer setups. Now installing a Tacoma Engine into a Hilux or Land Cruiser is a snap! Works on both Gear and Chain Drive Transfercases!
For 1992-95 V6 Applications, when converting to a Gear Drive T/Case Setup, the only previous option was to use a 1992-95 Factory Toyota 4cyl 5-speed Gear Drive T/Case VSS, that sells for $210. The New Marlin Crawler VSS saves $150 on a 1992-95 V6 Transfercase Conversion.
Please click here for more pictures.
Add To Shopping Cart MC-VSS, Electronic Vehicle Speed Sensor, $59
Marlin Crawler Vehicle Speed Sensor
